  New Posts New Posts RSS Feed - Calculation D2PAK
Calculation D2PAK
ThijsVerdonschot View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ThijsVerdonschot Quote  Post ReplyReply Direct Link To This Post Topic: Calculation D2PAK
    Posted: 17 Jan 2014 at 5:55am
I have to calculate a D2PAK footprint from ST Electronics.
In the library expert I only see the option to calculate a TO (DPAK).
Is it the best way to use the maximum with for the e1 value since the D2PAK has a kind of a T-shape?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2014 at 7:48am
I bet the component mfr. recommended pattern is not T-Shape, rather it's a full pad used for thermal relief.
You can use the TO (DPAK) component family to create a D2PAK footprint.
You can also select the "Footprint" tab and enter the mfr. recommended pattern (after you enter the component dimensions to calculate the IPC pattern).
Post Options Post Options   Thanks (1) Thanks(1)   Quote ThijsVerdonschot Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2014 at 8:53am
It is an thermal relief pad and the manufacturur recommended shape is 2mm larget then the lagest size.
I will use the TO (DPAK) to calculate.
Thank you for your quick reply.
