  New Posts New Posts RSS Feed - Switching Environments on a Current Part
BryanT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryanT Quote  Post ReplyReply Direct Link To This Post Topic: Switching Environments on a Current Part
    Posted: 13 Dec 2013 at 12:02pm
I'm having trouble switching environments on current parts.  For example, I build a part using the Nominal environment.  I decide that the pads are too large and I want to build in the Least env.  I dont see how I can do that.  I've had to go back, change the User default and re-do the footprint.  In your older tools I could easily switch between the environments and check the different results.  Did that change?  Am I doing something wrong - or missing something?
Thanks!
BryanConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2013 at 12:18pm
Some people get the User and Default Preferences mixed up.
In "Setup > Preferences > Design" if you select "User" it is a 1-Tier library system.
If you select Least, Nominal or Most it is a 3-Tier library system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryanT Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2013 at 12:27pm
Thanks - I understand that, but my question was how do I change it WHILE BUILDING A PART.  I had User Default set to Nominal when I built my part.  I decided to change it to "Least" but it doesnt change the footprint I built.  I have to start a new footprint to get the "Least" results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2013 at 12:47pm
You need to tell us what version of the program you are using and what component family you are trying to build (this is very important).
The V2013.17 works perfect for me and you seem to be the only one having problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryanT Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2013 at 12:57pm
Tom,
I upgraded to 2013.17 yesterday.
So here's a pic of the part I did - its in the PQFN with Tab Family.  You can see that its set for the Least Env:
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryanT Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2013 at 12:59pm
Then I changed the User Default to the Nominal Env - and then said "OK" again - should it update the footprint at that point?  It didnt in this case:
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2013 at 1:16pm
The default (or User) environment isn't applied until you select a component family.
If you change your preference while calculating any particular component family it won't be applied until you change the component family.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2013 at 1:17pm
When you are building a single Footprint, you change the environment in the Calculator, not User Preferences. Select the "Terminal > Environment > Dropdown"
But if you change any component dimensions, the preferences will reset to whatever your defaults are set to. Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryanT Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2013 at 3:20pm
AHHHH - Thats what I was looking for Tom.  Thanks - just couldn't seem to find that.  And after all that, looks like the pad size doesnt change when switching from L to N anyway.  But I'm thinking its because of the tight configuration of the landpattern.  There's no room for the pads to grow.  Anyway,  thanks for your help.  All looks good now.
Bryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2013 at 12:05pm
The Library Expert screen changes so fast that I cannot tell the difference when I change environments from Least to Nominal. The only thing that's noticeable is the Courtyard Excess spacing.
But you can easily see the pad dimensions when you switch environments by selecting the "Footprint" tab.
This page was generated in 0.311 seconds.
