  New Posts New Posts RSS Feed - Vertical Mount Axial Lead Part
Nightwish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nightwish Quote  Post ReplyReply Direct Link To This Post Topic: Vertical Mount Axial Lead Part
    Posted: 12 Dec 2013 at 1:51am
When I was using LP Wizard there is an option to switch between Horizontal and Vertical style for Axial lead components. But I can not see this feature in Footprint Expert. Is there a plan to add this feature back to Footprint expert? Sometimes our EE may have this requirements on some board.
Nightwish
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2013 at 7:42am
The "PCB Library Expert" has FP Designer to create these non-standard Footprints.
You create the pad stacks, silkscreen and pad spacing.
You are in complete control. Do you want a square pin 1 and a round pin 2? Do you want a circle or square silkscreen outline?
Try it and let us know if it works.
