  New Posts New Posts RSS Feed - 3-Pin Chip Package - SYFER_0805J1000472MXTE03
sgdavies View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sgdavies Quote  Post ReplyReply Direct Link To This Post Topic: 3-Pin Chip Package - SYFER_0805J1000472MXTE03
    Posted: 06 Dec 2013 at 4:58am
Hi All,
I have a slightly unusual package, which I can't find in the PCB Expert software to generate, I could do this manually of course, but I would rather keep everything IPC if possible.
Can somebody recommend how I do this in the PCB Footprint Expert? Cheers Tongue
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2013 at 10:46am
The Footprint Designer option in the Library Expert can do build this part.
For an example on how to use it:
http://www.pcblibraries.com/products/fpx/userguide/default.asp?ch=108
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2013 at 11:15am
You will need to use the manufacturer recommended footprint (not part of the screenshot above), but I searched online for the spec sheet for 0805J1000472MXTE03 and it is provided.
