  New Posts New Posts RSS Feed - Pad Size calculation
gedeakins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gedeakins Quote  Post ReplyReply Direct Link To This Post Topic: Pad Size calculation
    Posted: 27 Nov 2013 at 9:11am
I'm noticing that Footprint Expert does not take into account the lead thickness of certain devices (example D2PAK/TO-263AB) in the calculations?  Since IPC A-610 uses percentage of solder fillet -to- lead thickness in determining acceptance, wouldn't it be appropriate to incorporate this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2013 at 10:46am
The PCB Library Expert uses rules from IPC-7351 not IPC-A-610.
Please present your issue with IPC and let us know what they say.
Thanks!
This page was generated in 0.953 seconds.
