  New Posts New Posts RSS Feed - Pad-Free Mounting Holes for OrCAD PCB / Allegro
kwgilpin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kwgilpin Quote  Post ReplyReply Direct Link To This Post Topic: Pad-Free Mounting Holes for OrCAD PCB / Allegro
    Posted: 17 Nov 2013 at 12:27pm
When FPX creates a non-plated mounting hole (e.g. for a custom FP Designer component), it includes a pad that is sized smaller than the drill.  Cadence Pad Designer does not really like this and generates a warning.  Additionally, I have had at least one board house complain about this as well.
The better approach would be to use the "Mech pins use antipads as Route Keepout: ARK" option within Pad Designer.  When that checkbox is enabled, the copper pads can be set to a size of 0.0 while the thermal relief and anti-pad are define the route keepout area around the hole.
Can you make the necessary change to the translator?
This page was generated in 0.532 seconds.
