  New Posts New Posts RSS Feed - 2013.16 Released!!
2013.16 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2013.16 Released!!
    Posted: 06 Nov 2013 at 2:43pm
Version 2013.16 was just released!!
NEW:
FIXED / ENHANCED:
  • PADS Layout – Mounting holes pad stack diameter
  • FP Designer – Pins in certain parts were miss-numbered
  • Expedition – Direct Import offset problem for Checkerboard Paste Mask
  • Librarian – Manufacturer name auto-complete
  • 3D STEP – Color Option
  • Calculator – Quad Flat Packs with Thermal Pad solder mask
  • Calculator – Mounting Hole Inner Diameters is now calculated properly
  • Calculator – Solder Mask on Mounting Holes is now set properly
  • If a part or parts is unable to generate a 3D model, i.e. one built in the package designer, the user will now be notified
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2013 at 11:22pm
If you who did not get the email notification for the 2013.16 release from the Forum app, but received this post as an email notification, please send me a PM or reply. Some changes were made with the mail server component used and I'd like to see if this resolved the issue...
Thanks!
