  New Posts New Posts RSS Feed - Adding User's Define Naming Convention Output
FredBoyer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote FredBoyer Quote  Post ReplyReply Direct Link To This Post Topic: Adding User's Define Naming Convention Output
    Posted: 24 Oct 2013 at 2:00pm
It would be nice to be able to have a user's define naming convention for the footprint name & the 3D Model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2013 at 2:22pm
You can change the footprint name in both the CAD tool export menu (in both the LITE and Full Version) and in the Footprint cell in the Library Editor (in the full version).
If you add your part in a FPX file edit the Footprint cell and change the name. Then when you click on the line item to open it up in the calculator it will retain the changed footprint name.
If you "Batch" create a new library it will use your new footprint name.
The 3D model is always the same name as the footprint.
Let me know if this works.
