  New Posts New Posts RSS Feed - 2013.15 Released!!
2013.15 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2013.15 Released!!
    Posted: 22 Oct 2013 at 8:21am
Version 2013.15 was just released!!
NEW:
  • Through-hole Mounting Holes for plated/non-plated holes with round & slotted shapes, satellite vias and Donut pad shape option
  • Through-hole Calculators – Added ability to define custom (mfr. recommended) through-hole padstack
  • Through-hole Crystal component family w/3D model
  • 3D STEP – Relocate Pin 1 polarity marker depending if pin 1 is on side or center of QFP, QFN, PQFN
  • 3D STEP – Added new GUI to allow the user to change the Color of the component Body, Polarity and Lead
  • 3D STEP – Quality and TH Lead Length are now accessible from the STEP-only translator
FIXED / ENHANCED:
  • 2-Pin DFN – Pin pitch
  • Fixed an issue with Radial parts that was causing the leads to be the wrong height
  • Oscillator, Corner Concave 3D Model is properly seated on its leads again
  • Oscillator, Plated Through-hole 3D Model the leads not to display properly at a TH Lead Length of 0
  • Header, Right Angle Post 3D Model that was causing it not to display properly
  • FP Designer – Updated the GUI with improvements for ease of use
  • Expedition – Paste Mask should now be properly hooked to ASCII padstacks
  • Expedition – Fixed an issue that was preventing the stencil pads from being offset properly.
  • Expedition – Pads with a length by width will no longer have spaces around the 'x'.
  • 3D STEP – Header Vertical, both Round and Square holes, had graphical issues
  • 3D STEP – Non-Symmetric Left-Oriented parts (SOT223, SOT23, etc.), when built in a custom orientation, would not put out a proper 3D model
  • Anytime a footprint name is used in a filename or directory, a slash "/" will now be replaced with a dash "–"
  • Freestanding Arcs from FPX "Footprint Designer" now translate properly
