  New Posts New Posts RSS Feed - Making a Donut Pad Shape in Allegro
Kenny_kc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny_kc Quote  Post ReplyReply Direct Link To This Post Topic: Making a Donut Pad Shape in Allegro
    Posted: 21 Oct 2013 at 6:23am
Hello All,
I am beginner in Allegro so I need your help.
Can anyone tell me how to make a Donut Pad Shape in Allegro?
The Donut Pad Shape is where the inner part of pad there is no copper material so I can place another pad inside the Donut Pad.
So if anybody knows how to do this then please tell me. It's very urgent.
Romeo.C. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Romeo.C. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2013 at 5:33am
How do I create a pad with a void inside it?
1. Open a dra file for a package and move the origin somewhere to the center
2. Draw two circles in the Assembly Detail subclass at x,y ( 0, 0 ) representing the inner and outer extends of the donut. These are for construction purpose.
3. Set the grid to a small value such as .0005mm.
4. Using Add > 3pt Arc create a circle on the Etch Top subclass.  The first and second picks are each one grid point off the 12 o’clock zero X-axis on the outer circle.
The 3rd pick is at the 6 o’clock zero X grid location of the outer circle.
This is repeated for the inner circle.
5. Now add two vertical lines connecting the first picks and then the second picks.
6. Then, delete the two circles on the Assembly Detail subclass.
7. Go to Shape > Compose Shape
Click Right Mouse button and select Temp Group.  Pick both of the arcs and the lines, then click right mouse button and select Complete.
Right mouse click and select Done.
8. Now select Setup > Design Parameters and on the 'Design' tab set the Drawing Type to Shape. Ok out of the form and the Save this shape symbol file
This can now be called into the padstack where needed.
Related Solutions
·         How to create a donut shape pad?
Return to the top of the page
Document attributes
Solution ID:
11776508
Created:
02/16/2012 09:35:29
Last Modified:
02/24/2012 02:21:40
Product:
Allegro PCB Editor
Product Version:
Not Appropriate
HW Platform:
O/S Version:
SW Release:
mareespcb2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mareespcb2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 12:36am
Dear Romeo,
I followed your comments but error is showing on.
first one is
ERROR(SPMHA1-98): Illegal element class. 80151928 SHAPE @80151928
now I have deleted board geometry/ assembly notes then save the dra file again another is showing on.
ERROR(SPMHCS-3): Shape symbol cannot have a void in a shape. 83559776
Thanks for the advance
Mareeswaran k
Post Options Post Options   Thanks (0) Thanks(0)   Quote Romeo.C. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 5:11am
Hello
that's strange, I was able to create a donut pad without problems following exactly the steps as follows below.
After that you need to associate the new shape (*.dra, *.ssm) into the padstack editor with regular pad / geometry "shape" and browes ... selecting the new shape symbol.
Kind regards  Romeo
Steps
This page was generated in 0.346 seconds.
