  New Posts New Posts RSS Feed - Gull Wing Heel Size Changes In Least Mode
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Gull Wing Heel Size Changes In Least Mode
    Posted: 11 Oct 2013 at 12:37pm
In  creating a .5MM 8 Pin SOP in least mode. The heel in least mode is .25MM. When I change the pad length from .39MM to .40MM the heel value changes to .05MM.
I have the trim set to 0.00
Attached is a video.uploads/545/SOP_LEAST.zip
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2013 at 2:29pm
Thanks for the video...it really helps in this case.
Note in your video the terminal type.  When you change the L dimension the terminal changes from 'Outward L' to 'Gullwing'.  The two have different goals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2013 at 4:39am
Ok. I did not realize the type of terminal changes depending on the pad length.
Thanks! Again.
This page was generated in 1.501 seconds.
