  New Posts New Posts RSS Feed - Manufacturer List
Manufacturer List
IanOnBass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IanOnBass Quote  Post ReplyReply Direct Link To This Post Topic: Manufacturer List
    Posted: 23 Sep 2013 at 12:58am
Each time Library Expert is updated, the ManufacturerList.txt file is overwritten. This means that any user-added manufacturer is lost and so must be added again.
Suggest that a way is found to retain user-added manufacturers to avoid the resulting frustration and duplication of work.
For example, create a UserManufacturerList.txt file to which PCB Library Expert writes the user-added manufacturers (and the user may hand-edit, if desired) and when used by the software is 'merged' with ManufacturerList.txt.
Ian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2013 at 6:41am
I have a better idea.
Report all component manufacturer's to Support@PCBLibraries.com and they will be added to the next release and your component manufacturer's names will never get overwritten.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IanOnBass Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2013 at 7:11am
That works for me, Tom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2013 at 7:18am
Thanks! We need to know and add every component manufacturer not only to the software program, but also to the upcoming "Parts on Demand" (POD) search engine website which opens on October 1.
PLTcbv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2013 at 6:52am
Take a look at our site.
There are more than 1000 manufacturers listed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2013 at 7:22am
Great job and impressive list you got! But we're only interested in Component Manufacturers and not Electronic Equipment Manufacturers.
We started our list from Digi-Key, Mouser, Farnell, Arrow and Newark component distributors.
All of our customers can send us their component manufacturer's and we'll add them to the list in the "PCB Library Expert".
We need your help to create a best PCB library tool in the global electronics industry.
Thanks!  Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2013 at 8:18am
If you take a look in the English site version http://www.pltc.nl/en/links/manufacturers.html you will see that the section is called " Manufacturers".
I think that 99% is a Component Manufacturer.
Some old names are used with the new Manufacturer name in brackets, like Welwyn (TT Electronics)
Maybe you can use it for your database.
Most of the names we have used for our customers in 25 years of PCB design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2013 at 8:35am
This is very good stuff!
We derived the original Component Manufacturer list from Digi-Key, Mouser, Farnell, Arrow and Newark distributors.
Obviously they don't sell every component manufacturer's parts.
One of the challenges we have for the "Parts on Demand" (POD) project is that we need to gather up every component manufacturer's logo. I noticed that you already downloaded most of the logo's. Do you mind sharing them with us to eliminate duplication of effort?
Thanks!
