  New Posts New Posts RSS Feed - Output Rounded Rectanglar Pads Is Not OK
LVDB2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LVDB2013 Quote  Post ReplyReply Direct Link To This Post Topic: Output Rounded Rectanglar Pads Is Not OK
    Posted: 19 Sep 2013 at 2:11am
Result of rounded rectangular pads is not correct.
Snapshots below show settings and shapes in library expert versus results in expedition library.
Units are set in um and pad shapes are set as rounded rectangle.
Output : no rounded corners
units are in mm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2013 at 6:43am
Try this pre-release of V2013.14 and let us know if this issue is fixed - Click Here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2013 at 6:35am
Is this issue fixed? We'd like to release .14 ASAP. Let us know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LVDB2013 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2013 at 3:12am
Hello ,
Sorry for the late reply. I was in holiday last week.
Please find my findings below:
ASCII import:
Ascii import is not working for cells and padstacks. Mentor graphics doesn't allow import of unencrypted files anymore. The error message I receive is :
Error : Unencrypted data can not be imported.
          Please encrypt the data and try again.
Error - Parser initialization error =<3>
Direct import:
Shape of footprint seems to be ok but units settings of the cell is set in mm.
if you look at the properties of a padstack then the padnames are RndRec 550 x610. The  550 x 160 is in um the unit settings however are in mm. This is confussing and it implies that the padsize is 550mm x 160 mm. (see picture below)
The text size of the assemble and silkscreen reference designators are not correct. The definition in your tool is set as 1200 um. The exported footprint is 1.27 mm. Again the unit settings is not correct.
see picture below.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2013 at 5:56pm
Originally posted by LVDB2013 LVDB2013 wrote:
ASCII import:
We're aware of this. Older versions of Expedition do still have ASCII support, and some people can request it from MG(good luck on that), for those that have an expedition that can import ASCII, we still support it.
Direct import:
Not much I can do about that. Its a lacking of the DLL MG provides to import into their tool. The intention is for you to set the tool to um. The values of the pad are built in um, put in in um... but Expedition wants to display it in mm.
Our direct importer does not control text on direct import. It imports pads, graphics, and holes. What you're seeing there is the default put in by Expedition.
