  New Posts New Posts RSS Feed - Square Masks on Round Pads
kwgilpin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kwgilpin Quote  Post ReplyReply Direct Link To This Post Topic: Square Masks on Round Pads
    Posted: 10 Sep 2013 at 7:41pm
Some BGA manufacturers call for square solder and paste masks on top of round pads.  Can you make these independent options for both standard components and components created with FP Designer?
Thanks, as always,
Kyle
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2013 at 7:41pm
You can do this in FP Designer.
Create your BGA in the Calculator and then convert it to FP Designer.
Then select the Pad Stack editor and change the Paste Mask from Round to square with rounded corners.
Nightwish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nightwish Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2013 at 1:05am
Our DFME suggest to set the solder paste to Round Rectangular shape instead of a round one. The picture below can show the padstack for BGA in our library. The blue round shape is pad and yellow one is solder mask. The Rnd Rec shape in green is solder paste.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kwgilpin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2013 at 1:37pm
Sorry for the slow response.  The part in question in STMicro BAL-NRF01D3:
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00055606.pdf
Kyle
caclark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caclark Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2013 at 9:47am
Our Surface Mount SME also prefers slightly over-sized square paste on round BGA pads (been doing it for several years to all BGA packages with a pitch of 50 or less). We have seen a dramatic improvement on stencil release and pad to ball adhesion during reflow.
This page was generated in 0.233 seconds.
