  New Posts New Posts RSS Feed - 2013.10 Released!!
2013.10 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2013.10 Released!!
    Posted: 04 Aug 2013 at 8:02am
Version 2013.10 was just released!!
NEW:
  • 3D STEP – USR is now also filtered from the filename along with L, M, and N
 FIXED:
  • Assembly Outline User Preferences
  • DPAK Thermal Pad Solder Mask Swell
  • Success/Invalid Indicator and the Courtyard Origin
  • Through Hole Lead Width Ignored in SIP Package
  • Courtyard Origin Box Greying Out
  • Stencil Export to Expedition Incorrect
  • Eagle upgrades for proportional fonts
  • SON Pin 1 Building Too Short
  • PLCC – Fixed the graphical errors
  • 3D STEP Export User Setting
  • 3D STEP – Up, Down, Left, and Right orientations should now work properly
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 4:08pm
New 2013.10 build just uploaded.
  • Resolved issue causing an exception when the FP Designer body selection is 'None'
  • Courtyard size no longer adds the silkscreen line width if silkscreen is turned off
