  New Posts New Posts RSS Feed - Through-hole Solder Mask Swell Problem
jchauvin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchauvin Quote  Post ReplyReply Direct Link To This Post Topic: Through-hole Solder Mask Swell Problem
    Posted: 22 Jul 2013 at 10:33am
When through-hole parts are generated with swell and are saved inside of the library expert library, the swell settings are forgotten, upon re-opening the component.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 4:52pm
None of the user preferences are saved in the FPX file.
Only the component dimensions and part attributes are saved in the FPX file.
So you need to change your "User Preferences" to any Solder Mask Swell for every Terminal Type and then it will work perfect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchauvin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2013 at 10:58am
Got it, thanks.
