  New Posts New Posts RSS Feed - 2013.08 Released!!
2013.08 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2013.08 Released!!
    Posted: 18 Jul 2013 at 9:01am
Version 2013.08 was just released!!
NEW:
  • Added the Environment Level letter to the Footprint Name in the Print Feature
  • Pad stack names for IPC include thermal data (2013.08 - 2nd build)
FIXED:
  • FP Designer - Assembly outline size not changing
  • FP Designer - Mask and Stencil over/under size added to Through-hole
  • DIP, DIPS, SIP lead size not selecting the correct terminal goals
  • FP Designer Courtyard Crosshair checkbox not enabling
  • Pad stack Designer Proportional goals not setting correctly when ‘Lead Size’ is the source
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 4:36pm
A new 2013.08 build resolved these issues:
  • Problem with application of gang mask on Convex chip arrays
  • Problem with vertically oriented slots with round pads
  • Window close 'X' appearing in reference picture
  • Added 'Escape' key to bail on adding pins in FP Designer
  • Added 'Delete' key to remove selected pins
 This update is available as of 7:30EST, July 23, 2013.
