  New Posts New Posts RSS Feed - TO254P1419X457-3_4 or TO508P1419X457-3
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Topic: TO254P1419X457-3_4 or TO508P1419X457-3
    Posted: 05 Dec 2012 at 6:59am
I wondered generally how people treat a DPAK where pin 2 has been cut off such as:
http://www.onsemi.com/pub_link/Collateral/936-03.PDF
Do you enter it as:
TO254P1419X457-3_4
or
TO508P1419X457-3
I've been using TO254P1419X457-3_4 since I'm looking for the pitch of 2.54mm which is what the dimensioned drawing shows.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2012 at 7:10am
If you "Hide" pin 2 then the Pin Qty in the Footprint Name would be -3_4
The last pin number in the final footprint will always appear last.
So when you "Hide" Pin-2 you have a 3-Pin package and Pin-4 is the last Pin number.
If you "Delete" pin 2 then the Pin Qty in the Footprint Name would be -4_3
This means you have 3-Pins in a 4-pin package and Pin-3 is the last Pin number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2012 at 7:17am
Okay, thanks.
I'd only ever want to use the remove.
