  New Posts New Posts RSS Feed - TO-220 (Through-Hole) Staggered Pads significant?
Alex Quilty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex Quilty Quote  Post ReplyReply Direct Link To This Post Topic: TO-220 (Through-Hole) Staggered Pads significant?
    Posted: 08 Sep 2025 at 9:40am
Does it matter that the TO-220 Pads are staggered or in a row (assuming that the pads allow for proper clearance w/ no slivers)?
When should I use the staggered pads and when should I use the aligned row of pads if they are significant?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2025 at 11:38am
The only time you need to spread the terminal leads is -
  1. When the pin pitch is small and the pads violate the minimum pad to pad spacing
  2. When the component manufacturer's package comes with pre-bent leads
Otherwise, it's best to have the pads line up.
The 'D' and 'D1' dimensions would be the same value.
