Through-hole Solder & Paste Mask Pad Stack Issue |
Post Reply ![]() |
Author | |
m.elsayed ![]() Advanced User ![]() Joined: 22 Sep 2016 Status: Online Points: 196 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Oct 2025 at 12:13pm |
While I use Footprint Expert for creating a through-hole footprint, I find paste mask and solder mask not equal to Zero '0', also pad type not be simple type.
Tom H ![]() Admin Group ![]() ![]() Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5935 |
What's wrong with having negative values?
When a negative paste mask value is the same value as the pad, it turns off that shape. We don't understand what the issue is. We know that you want to see a zero '0' for the paste mask if there is none, but having a negative value is the same thing. |
1st - Pad type should be simple, not like shown in image
2nd - Solder Mask expansion = 0 and select not inherit Altium rule when building 3rd - Paste Mask value for fiducials should equal 0. However, a negative value appears |
There is no such thing as a negative Solder Mask on a pad.
i.e.: all SMD and PTH pads must have Solder Mask. The only time the value is negative is when the pad stack uses Solder Mask Defined technology. The Negative Paste Mask value only appears in Fiducials. Note: no one uses Local Fiducials any more. Ask your assembly shop if they need them. Surface Mount pad stack Paste Mask is the same value as the pad (1:1 scale) except for Thermal Pad checker board patterns. Through-hole pad stacks do not use Paste Mask unless you are using Pin-in-Paste (PnP) technology. If you use PnP technology then the Paste Mask value is normally 1:1 scale of the pad size (or bigger). |
Jeff.M ![]() Admin Group ![]() ![]() Joined: 16 May 2012 Location: San Diego Status: Offline Points: 491 |
The negative values are an artifact of the Altium translator script.
They are part of a perfectly good Altium footprint. Once the footprint is: imported into an Altium library; the library is saved; Altium is closed, then reopened the values will be appear as zero. There have never been any reported problems associated with this characteristic.
When you first import a part from footprint expert into Altium, but through hole pad stack will show a negative pace mask value.
However, when you close to him and reopen it and select the properties for the pad stack, the pace mask value will be zero. The negative value is only there temporarily until you close Altium and reopen it and everything is reset to normal.
Thanks , Tom, Jeff, got your reply for this point and will follow it and check
but still wait your support for the other 2 points:- 1- pad type should be simple not other type as shown in image 2- solder masl expansion should be zero not have vlaue
Post Reply ![]() |
Tweet |
