  New Posts New Posts RSS Feed - Through-hole Solder & Paste Mask Pad Stack Issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Through-hole Solder & Paste Mask Pad Stack Issue
    Posted: 20 Oct 2025 at 12:13pm
While I use Footprint Expert for creating a through-hole footprint, I find paste mask and solder mask not equal to Zero '0', also pad type not be simple type.
Attached FPX
Altium Screenshot:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 29 minutes ago at 10:29am
What's wrong with having negative values?
When a negative paste mask value is the same value as the pad, it turns off that shape.
We don't understand what the issue is.
We know that you want to see a zero '0' for the paste mask if there is none, but having a negative value is the same thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 23 minutes ago at 12:35pm
1st - Pad type should be simple, not like shown in image
2nd - Solder Mask expansion = 0 and select not inherit Altium rule when building
3rd - Paste Mask value for fiducials should equal 0. However, a negative value appears
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 1 minutes ago at 12:57pm
There is no such thing as a negative Solder Mask on a pad.
i.e.: all SMD and PTH pads must have Solder Mask. The only time the value is negative is when the pad stack uses Solder Mask Defined technology.
The Negative Paste Mask value only appears in Fiducials. Note: no one uses Local Fiducials any more. Ask your assembly shop if they need them.
Surface Mount pad stack Paste Mask is the same value as the pad (1:1 scale) except for Thermal Pad checker board patterns.
Through-hole pad stacks do not use Paste Mask unless you are using Pin-in-Paste (PnP) technology. If you use PnP technology then the Paste Mask value is normally 1:1 scale of the pad size (or bigger).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 19 minutes ago at 6:39pm
The negative values are an artifact of the Altium translator script.
They are part of a perfectly good Altium footprint.
Once the footprint is: imported into an Altium library; the library is saved; Altium is closed, then reopened the values will be appear as zero.
There have never been any reported problems associated with this characteristic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 36 minutes ago at 8:22pm
When you first import a part from footprint expert into Altium, but through hole pad stack will show a negative pace mask value.
However, when you close to him and reopen it and select the properties for the pad stack, the pace mask value will be zero.
The negative value is only there temporarily until you close Altium and reopen it and everything is reset to normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 50 minutes ago at 10:08pm
Thanks , Tom, Jeff, got your reply for this point and will follow  it and check
but still wait your support for the other 2 points:-
1- pad type should be simple not other type as shown in image
2- solder mask expansion should be zero not have vlaue
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 37 minutes ago at 12:21am
 i try  the point for paste mask expansion , but till gives negative  vlaues as shown in screen
