  New Posts New Posts RSS Feed - Through-hole,  Header, Vertical, 3D Model
mike_aes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike_aes Quote  Post ReplyReply Direct Link To This Post Topic: Through-hole, Header, Vertical, 3D Model
    Posted: 30 Sep 2014 at 7:21pm
I am unable to make the 3D model of the "Header, Vertical" work out correctly.  There is no overall vertical dimension that one can specify and as a result there are no pins on the bottom side of the header body than normally go into the PCB.
I think this is a bug.  Seems like you need an overall dimension to make it all work.
I am using Library Expert Pro Version 2014.11.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2014 at 7:31am
What version are you using? Latest stable build is 2014.11.
Post Options Post Options   Thanks (1) Thanks(1)   Quote mike_aes Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2014 at 8:22am
Hi Nick,
The latest version 2014.11.
I think there needs to be another vertical dimension to make it work.
I have not messed with the shroud, but to make it accurate, probably would need a height on that as well.
Mike
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2014 at 9:31am
Hi Mike,
You specify the height of the vertical header you want with the A value.
If you specify a TH Lead Extend value(in the 3D model group box just below Output Directory), that will determine how far below the origin and through the board you want the pins to extend. Its variable given thickness of the board, which is why you must declare it at the time of translation. If this value is 0, its the most likely reason why you're having a hard time seeing the pins.
Note: with a vertical header, the bottom of the pin is considered to be where the chamfer of the pin leading to the end starts so that its flush with the bottom of the header, which is at the origin.
Post Options Post Options   Thanks (1) Thanks(1)   Quote mike_aes Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2014 at 11:13am
Hi Nick,
That works!  Thank you.
To give feedback, it is not an obvious setting, but there maybe good reason for it to be three.  It would be helpful to have a note in the image where all the dimensions are to indicate that fact....it will likely save a lot of head scratching.
Mike
This page was generated in 0.184 seconds.
