  New Posts New Posts RSS Feed - Through Hole Header Pin 1 Dot
Todd Manning View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd Manning Quote  Post ReplyReply Direct Link To This Post Topic: Through Hole Header Pin 1 Dot
    Posted: 13 Sep 2015 at 7:18pm
When I generate a through hole vertical header component the Pin 1 Dot on the silkscreen doesn't appear despite having the "Silkscreen Pin 1 Dot Size" parameter set to 1.00mm. Is there some other setting that I am missing?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2015 at 3:19pm
We are adding Polarity Dots to Headers (and all component families) in V2016.
The user will be able to:
  1. Relocate
  2. Resize
  3. Delete
  4. Change shape to Triangle, Plus, Line, Diode
  5. Change layers from silkscreen to assembly
  6. Add additional Polarity. Say you want it outside on silkscreen but inside on assembly
It's coming.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd Manning Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2015 at 6:55pm
Excellent, thanks for the update.
This page was generated in 1.688 seconds.
