Thermal Pad Issue |
Post Reply ![]() |
Author | |
m.elsayed ![]() Advanced User ![]() Joined: 22 Sep 2016 Status: Offline Points: 72 |
![]() ![]() ![]() ![]() ![]() Posted: 15 hours 36 minutes ago at 5:56pm |
I can adjust Thermal Pad by this parameter, but when open in Altium gives wrong value.
Can have more explain how to adjust this?
Tom H ![]() Admin Group ![]() ![]() Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5865 |
80% Paste Mask Reduction will not give you a Checker Board Pattern.
80% Paste Mask Reduction will provide a single paste mask aperture. 70% is the highest Paste Mask Reduction to generate a Checker Board Pattern. |
i have attached fpx, can please we have explain on it ,
if 80% not applicable why tool not block user , rather than get wrong values, please add more details for this point, when apply 70 % what values should appears in Altium
You must consider all the rules.
You have a Minimum Paste Mask web set to 0.20 mm. You need to keep the Thermal Pad Paste Mask 0.10 mm indented from the pad edge. 80% is doable however, you're not going to get a Checker Board Pattern. Many users set Thermal Pad Paste Mask to 100% and allow the Assembly Shop Stencil Mfr. design the paste mask reduction. All we're saying is that we found out that 70% is the highest you can go a still get a Checker Board Pattern. We're not going to limit the software program and not allow 80%. If you're not educated on the mathematics of paste mask reduction, and the consequences of your Option settings, that's not our responsibility. It's trial and error. |
Post Reply ![]() |
Tweet |
