  New Posts New Posts RSS Feed - Support for Easy-PC (number one systems)
bald_bloke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bald_bloke Quote  Post ReplyReply Direct Link To This Post Topic: Support for Easy-PC (number one systems)
    Posted: 07 Jan 2015 at 7:10am
is there any support for Support for Easy-PC from number one systems? If not, are there any plans to add support in the near future?
Thanks.
jameshead View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 8:17am
IYou can use the Eagle output from PCB Libraries and import it into an Easy-PC library.
You have to run a script
LibraryToIntermediate.ulp
that is bundled with the program installation of Easy-PC.  This creates an Eagle intermediate ascii format file that can be imported to Easy-PC.  This script is run within Eagle and creates the file that can then be imported into the DesignSpark or Easy-PC library.
I've done this sucessfully.
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (1) Thanks(1)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 10:01am
You should also be able to export DesignSpark. This creates an Eagle Intermediate Ascii format file directly with a change in the header for DESIGNSPARK_INTERMEDIATE_ASCII.
The information I have for importing it is:
"in my case i simply exported from lib expert to designspark. Then in
libary - pcb footprints - open (the top button). Select your saved
file, click yes and voila your new footprint.
that worked for me in v15. It is similar to saving to .eip and then import."
Let me know if this works and I can clone DesignSpark to an Easy-PC translator and we can go from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bald_bloke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 3:29am
thank you for the replies. I tried the Eagle intermediate file and  that works in so far as I can import the sample file into easyPC. However, data ends up on the wrong layers. The placement courtyard ends up on the top copper layer, and the top silk screen is on layer 31. I can correct that on a component by component basis but it's not ideal.
The Eagle route is slightly long winded as I need to read the library file from PCB library expert into Eagle before I can create the .eil file.
I have requested an evaluation licence for library expert so that I can see if the designspark route is any easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 9:29am
You were sent the evaluation instructions. Please reply by email if there are any issues.
Regards,
Nick
Post Options Post Options   Thanks (1) Thanks(1)   Quote bald_bloke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 9:33am
Received now, thanks.
Regards.
