  New Posts New Posts RSS Feed - Standard Packages ie: SOT89
omar mahmoud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omar mahmoud Quote  Post ReplyReply Direct Link To This Post Topic: Standard Packages ie: SOT89
    Posted: 08 Apr 2015 at 12:50am
Would it be possible to add These standard packages SOT-89,TO-92,TO-251,TO-126 and TO-247 ?
Omar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2015 at 7:31am
There are less than 10 SOT89 and TO-92 packages in the world today.
Why spend any time creating a IPC Calculator for 10 packages?
Just build them manually using the mfr. recommendations and be done with it.
However, there are SOT89 and TO-92 packages on POD. Just search NXP mfr. and Case Code SOT-89.
Search Texas Instruments Case Code TO-92.
The TO-247 you can build in the PTH Through-hole "Flange Mount" component family. Already there.
The TO-251 is the SMD TO (DPAK) component family. Already there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote omar mahmoud Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2015 at 11:09pm
  • TO-92 and SOT-89 are widely used as package for the transistor and Linear Regulator there are more than 130 mfr. used this packages for example(Torex Semiconductor , Fairchild Semiconductor , RICOH Semiconductor , Seiko Instruments Semiconductor , Richtek Technology Corporation , ON Semiconductor , Micro Commercial Components , Microchip Technology , Renesas Electronics , Toshiba , New Japan Radio , Diodes Incorporated , Vishay , Central Semiconductor , Infineon Technologies AG , Exar , Maxim Integrated , Allegro MicroSystems , Linear Technology , etc) we have more than 60,000 components,and we can't build 3D Model for these parts.
  • I agree with you for TO-247 we can build footprint in the PTH Through-hole "Flange Mount" component family. but we need build 3D-Model
  • PCB Library isn't support TO-251 i think you have conflict between TO-251(IPAK) and TO-252(DPAK) ,TO-251 is the Through Hole package not Surface Mount.
  •  What about TO-126? also we need build 3D-Model for this package.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2015 at 5:43am
Library Expert already supports to TO (DPAK) Footprint and 3D Model in the Surface Mount component families. It's the last family in the list.
There are SOT89 and TO-92 parts on Part on Demand (POD) website.
Search for Diodes, Inc. or NXP Case Code SOT89
Search for DIGITRON Case Code TO-92
PCB Libraries, Inc. will create any SOT89 or TO-92 Footprint and 3D model to order. You order it on www.pcblibraries.com/downloads and we'll build it and make it available to the entire electronics industry. It's faster to manually create these parts than it is the create a unique calculator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2016 at 3:09pm
We added TO-92 component family in V2015.19.
SOT-89 is the only package you mention that Library Expert does not support yet.
This page was generated in 0.268 seconds.
