  New Posts New Posts RSS Feed - Square NO_PROBE For Round Radial Parts
mahmoodv99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Topic: Square NO_PROBE For Round Radial Parts
    Posted: 25 Apr 2016 at 9:31pm
Library Expert V2016.03 Allegro Output NO_PROBE area is generated as square instead of Round for Radial LED.
Same issue existed in V2015.21 and I posted the problem in forum back then, but it's still not fixed.
I'm adding a 1.9 mm Excess "NO_PROBE" from component body, component body is circle, then why is "NO_PROBE" coming as square?.
I want a ROUND shape for Allegro "NO_PROBE".
The same issue exists for round Radial [Electrolytic].
Can you fix this?
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 11:48am
I'll take a look and see if I can come up with a resolution for this. Right now it uses a square because its going to the extents of the particular shape. Its not really based on whether or not its square. I'll see what I can do though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 1:09pm
This issue will be fixed in V2016.04 to be released by Monday May 2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2016 at 8:06am
Let us know if V2016.04 fixed your problem.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 5:03am
Thanks!
Not fixed, still same problem Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 12:32pm
Can you post a picture of what you are getting?
Also, V2016.05 pre-release is available here - www.pcblibraries.com/downloads
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 12:54pm
Simply select the Radial LED Reference part and No Probe should be Courtyard. Output to Allegro and it should work. If you're trying to do something other than that, let me know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2016 at 8:37pm
Not OK when selecting No probe excess as Component Body.
Its OK when selecting No probe excess as Courtyard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2016 at 8:39pm
I want to use Components Body as reference.
Hope you will fix it in next version.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2016 at 7:17am
We recommend that you remove the courtyard "Excess" so that it hugs the Footprint Boundary.
We cannot change the square NO_PROBE to Round Shape.
I notice that you are putting an "Excess" value in your NO_PROBE setting. Just use the Courtyard which is 0.25 mm Excess and add on to that.
