Specified vs calculated nominal sizes |
JJonas
Topic: Specified vs calculated nominal sizesPosted: 13 Apr 2015 at 3:54am |
Usually lower and upper deviations from nominal sizes are specified to be the same. However, that is not always the case. For example, nominal size can be specified to be 1.0 with lower deviation of -0.1 and upper deviation of +0.3. In this case your application recalculates nominal size to 1.1. This issue becomes relevant in case I select silkscreen outline to be drawn to nominal body size - I expect to have manufacturer specified width and length, not recalculated ones. What is also affected is 3D models.
Why have you chose to recalculate manufacturer specified nominal sizes?
Joined: 05 Jan 2012 Location: San Diego, CA Status: Online Points: 5993 |
Posted: 13 Apr 2015 at 7:00am |
The Tolerance Deviation of -0.10 mm to +0.30 mm does not play into the mathematical model of the IPC-7351 land pattern calculation for the resulting pad size. You can enter -0.10 mm to +0.30 mm or +/- 0.20 mm and get the same results. We've been creating land pattern calculators since 2001 and while we really appreciate users to challenge the standard to find flaws or suggest a better solution. We know that some mfr. tolerances are uneven and you can put them in the calculator uneven, but the program will make them even. Maybe this is something we need to look into for the V2016 Library Expert rewrite. The code is getting old and we need to create a brand new tool to make it look like 2016 to work with Windows 10 coming this October. |
