SOT89 Package Footprints |
m.elsayed
Topic: SOT89 Package FootprintsPosted: 7 hours 1 minutes ago at 7:07am |
Part Number: PXT2907A,115 Case Code: SOT89 Manufacturer: Nexperia Supplier link: https://www.nexperia.com/product/PXT2907A Pad Shape is flat and can't find this shape in the Surface Mount component families. |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5978 |
Posted: 5 hours 26 minutes ago at 8:42am |
The Nexperia PXT2907A,115 is on www.pcblibraries.com/POD
It's available for free download. Components with irregular shaped pad stacks are created in a CAD tool and imported in the FPX file library. You must select the FPX file Row and use Batch Build to create the footprint. All SOT89 footprints use the mfr. recommended pattern. However, you could potentially create this footprint in FP Designer. |
m.elsayed
Posted: 3 hours 20 minutes ago at 10:48am |
Can please add more details and provide steps for creating this package with screen shoots
Posted: 2 hours 28 minutes ago at 11:40am |
The Nexperia SOT89 uses the Mfr. Recommended Pattern.
This footprint requires custom paste mask but it still doable in FP Designer. Doing step by step instructions would be rather lengthy. In FP Designer you could create pin 2 with two pads pins 2a and 2b and when you import to Altium it will rename the two pins to Pin 2. You can also add the custom Paste Mask using Drafting Outlines on the Paste Mask layer. ![]() |
m.elsayed
Posted: 2 hours 3 minutes ago at 12:05pm |
Thanks Tom for your support
However This something need your extra effort from your side to make steps for it But it will be more helpful so that I can create it b following your steps Can please provide steps on details please
Posted: 1 hour 56 minutes ago at 12:12pm |
FP Designer has the same features for all footprints.
Once you know how to build one FP designer footprint, you should be able to create every non-standard footprint. Watch this video: This will review how to Create:
