SOT-363 IS A SOT-23 OR A SOP
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: SOT-363 IS A SOT-23 OR A SOP
    Posted: 10 Mar 2021 at 5:45am
Hi to all,
I have a question with the next component: Diodes BAV99DW-7-F.
According with the data, it is a SOT-363 package.
When I start creating the component with PCBLibraries I don't know if it is a SOT-23 package with outward L lead or a SOP with L lead.
For example, for NXP the SOT363  is a TSSOP6.
I checked the footprint in both cases
- SOP6P65_200X210X110L32X20N
- SOT23-P65_210X110L32X20N
and they are similar
 S=1.15mm L=0.79mm, W=0.37mm
I know that both packages come from the JEITA SC-88, but if I create it using a SOT23 model or a SOP model the final name of the footprint is different and it could create problems.
Has anyone had any similar experience?
Thanks to all for your comments.
dramos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 8:56am
TSSOP = Thin Shrink Small Outline Package
Thin = What? Who decides what Thin is?
Shrink = Fine Pitch. What is "Fine Pitch" today?
TSSOP is a mfr. created marketing name because they want to promote their Thin Fine Pitch package.
In today's reality, it's just an SOP, which is an Integrated Circuit.
SOT = Small Outline Transistor.
Every NXP Case Code starts with SOT. It's their way for creating a Case Code ID. They're not all Transistors, most of them are semiconductors. It's just a Case Code.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2021 at 12:03am
Thanks for sharing your Knowledge!!!  Smile
In my particulary situation with the diode BAV99DW-7-F, I will use the SOP model instead the SOT only because SOT has the word transistor and the compnent is not a transistor and SOP is more generic name: "Small Outline Package".
Best regards.
dramos
