Some Footprints Are Only Available In PADS Viewer |
layouter88
Joined: 12 Jul 2012 Location: Germany Status: Offline Points: 79 |
Topic: Some Footprints Are Only Available In PADS ViewerPosted: 23 Feb 2024 at 2:21am |
Hello together, I use actual SW 24V04. I need a TI_RPJ0009A footprint, which is available in the semiconductor library. But when I click on it, only the PADS Viewer opens and I am not able to build the footprint. What do I have to do? Thank you for your support. Erwin
Nick B
Posted: 23 Feb 2024 at 7:19am |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Online Points: 5993 |
Posted: 23 Feb 2024 at 9:00am |
You must be using an old version of Footprint Expert.
The TI_RPJ0009A footprint is an FP Designer part created in V24.05 Footprint Expert pre-release. V24.05 will be officially released next week. The Texas Instruments Case Codes were updated in the latest version of Semiconductors dated 2/9/24. It's not a PADS file. The only reason we create some footprints in PADS is due to irregular pad and body shapes. Then we export the ASCII files and import them into FPX file format. You need to create PADS parts by selecting the FPX file Row and select "Batch Build". |
layouter88
Posted: 27 Feb 2024 at 1:11am |
Tom, thank you very much. Even this was a missunderstanding, your answer gave the solution. The missunderstanding was that I meant the footprint preview window in Footprint Expert which has the title Pads Viewer. Best regards, Erwin
