  New Posts New Posts RSS Feed - Solder Mask on Power Pads
tomasc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomasc Quote  Post ReplyReply Direct Link To This Post Topic: Solder Mask on Power Pads
    Posted: 16 Oct 2023 at 6:15am
When generating footprints with power pads (For example QFN, PQFN etc.) and importing them into Altium Designer, these pads are covered with Solder Mask.
It looks like the "Top Paste" layer is made into "Top Solder" which means there is solder mask on a solderable pad.
Which settings I should change to make a power pad into a one "Top Solder" layer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 8:48am
Solder Mask is a Negative image.
The Thermal Pads are no covered in Solder Mask, the solder mask is completely removed from all pads.
Paste Mask is a Positive image and Solder Mask is a Negative image.
You're mixing you layer assignments up.
Top Solder layer = Solder Mask
Top Paste layer = Paste Mask
We never had a problem with this in the past 20 years.
Maybe I'm missing something that needs more explanation. If so, please elaborate.
Thanks
