SMPC (TO-277A) made out of DFN standard
zentekfr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Topic: SMPC (TO-277A) made out of DFN standard
    Posted: 23 Feb 2022 at 3:57am
In the process of building a footprint for a SMPC component (standardized against JEDEC TO-277A), I found that a 3-pin DFN could do the job. The obtained land pattern is very close to the manufacturer's recommended footprint. Of course the pins should be reordered/renamed.
Is my idea of building this part out of a DFN3 good? Not advisable? And why?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 6:06am
I add the drawings and datasheet for reference: https://www.vishay.com/docs/89335/ar4pm.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 9:45am
The Vishay TO-277A Case Code is not a 3-pin DFN component family.
This footprint must be created in FP Designer.
There are 34 Vishay part numbers on www.pcblibraries.com/POD that have the TO-277A Case Code.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 12:58am
Hello Tom,
Of course it's not a DFN. But as soon as I use the FP Designer, I'm losing much of the features of Footprint Expert (3-tier density system, rounded rectangle pads, pad shapes drawing, Master options for batch generation, ...).
That's why I considered building it from a known standard package.
Thanks for your answer Wink
Justin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 10:42am
In FP Designer you have 100% control of the pad stacks like Rounded Rectangle Pads and Pad Shapes.
All non-standard package footprints should be created in FP Designer.
This is not a 3-Tier Density footprint. Only the mfr. recommended pattern will work correctly.
If you need FP Designer training, we can do a quick webcast so I can show you some great features.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2022 at 10:22am
So I probably missed the rounded rectangle option.
Then a webcast is welcome! I will send you an e-mail.
This page was generated in 3.643 seconds.
