  New Posts New Posts RSS Feed - SMD vs. PTH Outline and Footprint Name
stanleycayochok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanleycayochok Quote  Post ReplyReply Direct Link To This Post Topic: SMD vs. PTH Outline and Footprint Name
    Posted: 31 Aug 2021 at 8:27pm
Is there a reason why PTH use maximum dimension while SMD uses nominal dimension for outline mapping and footprint naming?
Would it be possible to add an option for PTH to use nominal instead of maximum?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2021 at 9:15am
It's because at the time we created the calculator, most manufacturers only provided Maximum body dimensions for most Through-hole component packages.
A spot check of data sheets shows this is still the case.
There's also the practical reason to provide a more realistic and consistent graphic representation of the terminal relationships to the body for SMD parts because of tighter sizes and tolerances.
This page was generated in 0.492 seconds.
