  New Posts New Posts RSS Feed - SMD BGA Pads
SMD BGA Pads
david.vrtaric View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david.vrtaric Quote  Post ReplyReply Direct Link To This Post Topic: SMD BGA Pads
    Posted: 19 Sep 2019 at 1:00am
I want to create BGA 0.40 mm pitch footprint.
So if the pitch is 0.50 mm or less then we should create a SMD ( solder mask defined ) pads.
i entered 0.40 mm pitch and BGA Non-Collapsing Ball but the Library Expert is always creating NSMD pads?
Is it possible that the Library expert creates SMD pads for BGA per IPC standard?
Br.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 8:38am
Yes, you would use a Non-Collapsing BGA Pad.
IPC has no recommendations on Solder Mask defined BGA pads.
This issue is between you and your assembly shop and quality control managers.
