  New Posts New Posts RSS Feed - SIP-4L, Diodes
SIP-4L, Diodes
saidzaky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote saidzaky Quote  Post ReplyReply Direct Link To This Post Topic: SIP-4L, Diodes
    Posted: 06 Nov 2014 at 7:41am
We are working to develop footprint model for SIP-4L using 2014.12 version and need to build it for Eagle, it would be great if you could help me.
this package has 1.27mm pin pitch and its terminal  dimensions (0.44 Max & 0.41 Max) mm, there are more details in package drawing in page #5 in this datasheet - www.diodes.com/datasheets/AH276Q.pdf
In this case, the Padstack would be c145h85 but the issue is the Padstacks are overlapped
What are the right padstack dimensions (for L, N, M)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2014 at 8:56am
I would use FP Designer to create this part in 3 minutes.
In V2015.02 there are no 3-Teirs for through-hole.
IPC disqualified the IPC-7251 through-hole 3-Teir library system.
Read this -
http://www.pcblibraries.com/forum/ipc7251-3teir-pth-pad-stack-obsolete_topic1463.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2014 at 8:59am
I forgot to mention that the FP Designer can do Oblong through-hole pad shape to avoid pad overlap and still provide a good solder joint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote saidzaky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2014 at 8:28am
Thank you.
