  New Posts New Posts RSS Feed - SC70 4-Pin With Power Pin on Pin 2
O.Mueller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.Mueller Quote  Post ReplyReply Direct Link To This Post Topic: SC70 4-Pin With Power Pin on Pin 2
    Posted: 11 Jun 2013 at 2:08am
Hello All,
Does anyone have a solution to setup a SC70 4-pin package with the location of the Power Pin on Pin 2?
The SOT143 shows the right picture but set the Power Pin to Pin 1.
The component datasheet is here -
Thanks Olaf
layouter88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote layouter88 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 3:17am
Hello Olaf,
If you don't want to change this manually, you could use SOT192P210X110-4R (KS-4) from the SM.fpx library, which is a SOT143 with Power Pin on 2
Best Regards,
Erwin
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 3:27am
Click the MIRROR button after you've entered the dimensions and select OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 3:30am
Oh, and renumber the pins and change the silkscreen & assembly orientation markings afterwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 6:31am
I think you need to "Re-number" the pins first, then "Mirror" the part.
Try it and let us know if you're successful with what you need.
If not, we can fix it to do whatever you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.Mueller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 10:49pm
Hello Tom,
It works with the Renumber and Mirror.
But I must also change to Orientation From Left to Right.
This Orientation Change is not marked in the Library.
When I will do a batch later I must have in mind that the orientation for this component is different.
How we can handle this ?
Thanks Olaf
