  New Posts New Posts RSS Feed - Rounded Corners on Thermal Pad Stencil Apertures
felecro View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote felecro Quote  Post ReplyReply Direct Link To This Post Topic: Rounded Corners on Thermal Pad Stencil Apertures
    Posted: 15 hours 31 minutes ago at 2:40am
Is there are a reason why stencil opening for under body thermal pads have sharp corners?
Would it be possible to have an option to make them round?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 31 minutes ago at 8:40am
Yes, you can make the Stencil Apertures rounded corners.
Move the Calculator footprint to FP Designer and you will have full editing of all pad stack layers.
You can save the Calculator part n FPX for the high-quality 3D STEP Model.
Use the customized pad stacks in FP Designer as your footprint.
Make sure that the Calculator Part and the FP Designer part have the same Footprint Name in the FP Library. We also make the Physical Descriptions match. We use the FP Designer autogenerated Physical Description.
Create the Footprint with the FP Designer 3D STEP first and the high-quality Calculator 3D STEP model second and overwrite the original 3D STEP.
Watch this video on how to move a footprint from the Calculator to FP Designer:
