  New Posts New Posts RSS Feed - Round off in footprint expert calculator
eaglor View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote eaglor Quote  Post ReplyReply Direct Link To This Post Topic: Round off in footprint expert calculator
    Posted: 28 Aug 2024 at 10:20am
Hi All
I am using the Footprint Expert SMD Reference Calculator.xlsx.
I have a question about the round off when calculating the footprint pad size and spacing.
Why does it round the C(Center to Center Spacing) and X value, not the ZMax and GMin value?
Is it compliant with IPC7351B standard?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 10:39am
You should download and install the V24.10 Footprint Expert Calculator to get better results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eaglor Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 10:41am
Thanks, Does the "V24.10" round the ZMax and GMin value, not the C and X value?
Post Options Post Options   Thanks (1) Thanks(1)   Quote eaglor Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 10:44am
I am comparing the formula difference between Altium Designer and Footprint Export, just want to know which one is better? which value should be round to compliant with the B standard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 1:41pm
Altium uses the original 2005 IPC-7351 release.
V24.11 Footprint Expert uses a combination of these standards and guidelines:
  • IPC-7351B (Mathematical model)
  • IPC-7352 (Pad Stack naming convention)
  • IPC J-STD-001 (Solder Joint Goals)
  • IEC 61188-7 (Zero component orientation)
  • IPC-7093A (Solder mask defined thermal pads)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 1:46pm
After calculation of a footprint, select the Footprint panel > Calculation Details.
