  New Posts New Posts RSS Feed - Renumbering Calculator Parts
RWbeckett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RWbeckett Quote  Post ReplyReply Direct Link To This Post Topic: Renumbering Calculator Parts
    Posted: 23 May 2017 at 7:44am
Is it possible to re-number calculator parts?
Say, if I wanted to re-order them or re-name them altogether?
Andrew Benson
R.W. Beckett Corporation
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 7:50am
You should be using V2017.13 as we just fixed a rename bug in that version.
You can rename pins in SOT23 and DPAK and you can relocate pin 1 if other component families.
If you need to rename pins in a unique way, relocate the part into FP Designer and have total freedom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 9:19am
Use the Right Mouse Button in every Calculator form to see the options in each component family.
