  New Posts New Posts RSS Feed - Remove Val** in KiCad output
Fredric View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fredric Quote  Post ReplyReply Direct Link To This Post Topic: Remove Val** in KiCad output
    Posted: 10 Sep 2025 at 1:40am
Is there any setting to stop the Val** text on F.Fab layer to be created in KiCad output footprints?
In older version of KiCad I believe that Val** was mandatory, but this is not true any longer.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 7:39am
Go to 'Tools > Options > Drafting > Silkscreen > All Density Levels > Add Value to Footprint > Uncheck it'
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fredric Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 45 minutes ago at 4:32am
Thank you Tom.
I had already tried that but I didn´t work. Or I thought it didn´t work.
Now I have looked more carful at the output and I understand what is happening.
The generated file does indeed not include Value. but when KiCad opens the footprint and Value is missing then it adds it because Value (and Reference) must exist.
What need to be done if Value is disabled, is to set Value to hidden in the output file. The same goes for Reference.
So maybe this is almost to consider a bug? Or feature request? :)
