  New Posts New Posts RSS Feed - Reference designator position in Altium Designer
felecro View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote felecro Quote  Post ReplyReply Direct Link To This Post Topic: Reference designator position in Altium Designer
    Posted: 28 Jan 2025 at 5:20am
I would like to check is there an option to customize the location of reference designator in Altium Designer.
In the older versions of FP Expert (older than 25.xx, possibly 25.02 as reference designator location was mentioned in the changelog) the location of the designator was in the center of the component bust justified to the left, with the dot of the ".Designator" string being positioned in the upper right quadrant of the footprint.
In the newest version it is still positioned in the center but the text is justified to the center vertically and horizontally. I also noticed that the position can be reverted to the old pattern by using the undo action after the import script is finished running. This is not possible when a footprint is generated in one of the old versions of FP Expert - the undo button is greyed out.
Can this be customized or is this the default positioning of the reference designator going forward?
Or is this some kind of software bug?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 8:42am
By popular demand from many Altium users we changed the .Designator justification to Center/Center.
Altium scripting makes altering text justification very difficult and until that changes we have no plans for providing a user preference.
Post Options Post Options   Thanks (1) Thanks(1)   Quote felecro Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 11:20pm
OK, thanks for answering my question
LaurenFoster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaurenFoster Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2025 at 2:56am
Thanks for answering, you saved my day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2025 at 8:15am
The latest release of V25.03 has the .Designator for Silkscreen and Assembly set to Center/Center justification.
In Tools > Options > Drafting, you can adjust the Height and Width and there's on/off switches.
In the Altium translator you can change the layer assignments.
Here is the new default Layer Assignments that Altium released on 11/1/2024.
This page was generated in 0.311 seconds.
