  New Posts New Posts RSS Feed - Rectangular leads
Rectangular leads
magnus.lictor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Topic: Rectangular leads
    Posted: 20 Aug 2024 at 1:03am
For through hole headers, I cannot set the lead shape to rectangle.  This option is available in the 'Padstack Calculator' but not in the  Through-Hole  'Component Type = Header' calculator.
For now you have to play with the drill size for square or round pin until you get the drill/pad  that the 'Padstack calculator' has calculated for the rectangle pin, or modify the pads/pins in Designer.
Like, the Samtec SSW series of headers that have a rectangular pin of 0.41x0.79mm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2024 at 9:07am
Use FP Designer to create Rectangular pads for through-hole footprints.
Most SAMTEC connectors and Headers and created in FP Designer.
Are you using www.pcblibraries.com/POD ?
There are thousands of free connectors there, most created in FP Designer.
Also, Footprint Expert comes with a Connectors library and they are all created in FP Designer.
This page was generated in 0.703 seconds.
