  New Posts New Posts RSS Feed - QFP Local Fiducal Flag Not Saved to Library
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: QFP Local Fiducal Flag Not Saved to Library
    Posted: 18 Jul 2016 at 2:10pm
When I save a QFP to the library with fiducials off and then reload the footprint from the library fiducials turn back on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 2:14pm
Then change the QFP Preference rules that are turning the Local Fiducials on.
Preferences > Components > Surface Mount > Quad Flat Pack (QFP, CQFP) > Add Fiducials When Pin Pitch is Less Than 0.625
Make the value 0.10 and you'll never get Local Fiducials unless you turn them on in the Calculator and Save to FPX.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 2:19pm
OK. I will do that. Thanks
