  New Posts New Posts RSS Feed - Problems With Hole Mounted D-Sub Connector
BennsPCB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Topic: Problems With Hole Mounted D-Sub Connector
    Posted: 05 Sep 2017 at 1:03am
I'm trying to generate a OrCAD footprint for a D-Sub connector (Harting_09663516512).
In LE (v.2017.17) it looks fine but in OrCAD (v. 17.2 S024) the 3.20 mm holes are 1.00 mm.
Library Expert
OrCAD
jgregoire View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jgregoire Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 9:02am
Workaround: delete the last two lines from the .scr file for that padstack:
QtSignal MainWindow Save triggered
QtSignal MainWindow Exit triggered
Then run the .bat file.
This time the pad stack editor will open and wait for you to save the file.
Manually save it, ignoring the warnings.
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 9:38am
User Guide here: https://www.pcblibraries.com/products/fpx/userguide/default.asp?ch=206
Specifically follow the instructions on setting up your Allegro for FPX.
Setup -> User Preferences. Go to UI -> Padstack_editor. The options should match the below with 2 of the 4 boxes checked. Then the warnings should be filtered allowing the padstacks to save.
