  New Posts New Posts RSS Feed - Printing: More Output Possibilities
FranzR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FranzR. Quote  Post ReplyReply Direct Link To This Post Topic: Printing: More Output Possibilities
    Posted: 19 Mar 2014 at 8:02am
is it possible, to get settable printing options for output a detailed documentation of the current displayed part and options?
for e.g.:
- Settings
- Terminal --> Settings, Environment, ...
- Rules
- Drafting
- Assembly, Courtyard, ..
- Program Version, Warnings
- Current name of configuration
So it can completely reproduced (*.pdf) with which configuration the part was built, or if the current settings are changed before build.
Because i have seen, that if the component settings were changed an the part was saved in the library, than the changed settings are not included in the library and the builded part was not repeatable.
Here was an example made with LP Wizard:
Post Options Post Options   Thanks (0) Thanks(0)   Quote FranzR. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2014 at 8:09am
This page was generated in 0.191 seconds.
