  New Posts New Posts RSS Feed - PLCC
PLCC
magnus.lictor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Topic: PLCC
    Posted: 31 May 2021 at 5:42am
Can you tell me what the D2 dimension stands for. As it is not a dimension in my datasheet but required by the footprint designer.
And, when the D2 dimension is not applicable what should I use?
regards, Charles
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 9:01am
D2 = The Terminal Lead Center.
Most PLCC mfr.'s provide that dimension.
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 11:34pm
Tom,
Thanks for your reply. Did not recognize this dimension as the Terminal Lead Center.
And you are right, that dimension is in my datasheet.
Thanx, Charles
