  New Posts New Posts RSS Feed - Placement Accuracy
Placement Accuracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Placement Accuracy
    Posted: 12 Oct 2025 at 1:22am
How do I apply Placement Accuracy in the master option file?
Land pattern with dimension| at 'Maximum Material Condition' profile tolerance of part (0.2 X 2), plus profile tolerance of land pattern (0.05 X 2) plus placement accuracy (0.10 diameter of true position) are considered in determining the proper dimension for [Z], plus
the desired toe fillet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2025 at 11:05am
Can please check this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2025 at 11:35am
(Main Menu Bar)
Tools > Options > Calculator Options > Design > Decimal Place Accuracy > Calculated Footprint > Pad Place.
This setting applies to all calculated parts and all material conditions.
This page was generated in 0.330 seconds.
