  New Posts New Posts RSS Feed - Pin in Paste
Pin in Paste
phil.holden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phil.holden Quote  Post ReplyReply Direct Link To This Post Topic: Pin in Paste
    Posted: 12 Jan 2023 at 8:09am
Are there any plans for inclusion of a 'Pin in Paste' hole size calculator? Or does anybody have any credible information regarding making this calculation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2023 at 9:44am
Pin-in-Paste has been a feature in Footprint Expert from the first release.
Tools > Options > Console > Generate Through-hole Paste Mask
This will add paste mask to all through-hole footprints.
You can turn it on to create an entire library with Pin-in-Paste technology using your existing FPX file library.
You can add a Density Level (Suffix) modifier to identify the footprints that have Paste Mask. I recommend "P" or "PIP". Use the "Overwrite Footprint Name Suffix" option right above the "Generate Through-hole Paste Mask" button.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phil.holden Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2023 at 2:55am
I know we have had the ability to include the paste mask in through-hole footprints. I was wondering whether there was an actual calculator for getting the hole-to-lead ratio correct for the purpose of PIP technology?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2023 at 9:38am
There is not a Pin-in-Paste calculator as there is no guidance from any world standards group like IPC.
When I see a Pin-in-Paste in the mfr. recommended pattern, they normally call out the paste mask size.
If you have a known calculator for Pin-in-Paste technology, please send it to us.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2023 at 10:35am
There is a feature in Footprint Expert called "Incremental Pad Stack" in which the pad size annular ring gets bigger an bigger depending on the terminal lead size.
The calculation is - Pad Size is 1.5X of the hole size.
1 mm hole = 1.5 mm pad (0.25 annular ring)
2 mm hole = 3.0 mm pad (0.50 annular ring)
3 mm hole = 4.5 mm pad (0.75 annular ring)
4 mm hole = 6.0 mm pad (1.00 annular ring)
The hole size is calculated from the max. lead diameter.
So the 1.1 scale paste mask over pad size should be adequate, but I see Samtec connectors call out large paste mask sizes in their datasheets.
felecro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote felecro Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 4:54am
Would it be possible to implement this kind of calculation for PiP mask in the future revisions of Footprint Expert?
https://software.indium.com/stencil-coach/pin-in-paste-apertures.php
This page was generated in 0.283 seconds.
