  New Posts New Posts RSS Feed - Pin header with pins which are not centered
Guido View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guido Quote  Post ReplyReply Direct Link To This Post Topic: Pin header with pins which are not centered
    Posted: 11 Dec 2014 at 1:40pm
my question refers to the Library Expert Lite 2013 (I know it's an older Version). Is there a way to create a footprint for a single row pin header which pins are not centered in reference to the plastic? The following datasheet shows a example of such a pin header. With reference to the short side of the plastic, the pin row is not in the middle.
http://media.hr-connector.com.tw/A2542WV-XPNXXXXX01X.pdf
Best regards
Guido
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2014 at 2:15pm
Not in the free Library Expert Lite.
But certainly in Library Expert Pro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guido Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2014 at 3:31pm
Hello Tom,
thank you very much for your reply. For me (student) the Pro version is a bit too expensive. So I have to correct the offset by myself. Is it common to include this offset in the naming of the footprint? If yes, where should I insert the offset in the following example of a 6 pin header?
SHDRV6W64P254_6X1_1524X580H1080B
Best regards
Guido
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2014 at 5:05pm
For all connectors, I would highly recommend this naming convention as it's perfect for connectors.
MfrName_MfrPartNumber
3M_Part Number
AGILENT_Part Number
AIRBORNE_Part Number
AMPHENOL_Part Number
AVX_Part Number
BERG_Part Number
BLOCKMASTER_Part Number
CUI_Part Number
JOHNSON_Part Number
ERNI_Part Number
FCI_Part Number
FUJITSU_Part Number
HARTING_Part Number
HIROSE_Part Number
IEH_Part Number
ITT_Part Number
JALCO_Part Number
JWT_Part Number
JST_Part Number
KEYSTONE_Part Number
KYCON_Part Number
LEMO_Part Number
MILL-MAX_Part Number
MOLEX_Part Number
NEUTRIK_Part Number
PHOENIX_Part Number
PULSE_Part Number
RIA_Part Number
SAMTEC_Part Number
SIEMENS_Part Number
SPEEDTECH_Part Number
STEWART_Part Number
SULLINS_Part Number
SWITCHCRAFT_Part Number
TE_Part Number
YAMAICHI_Part Number
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guido Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2014 at 4:54am
Hello Tom,
thank you for your hint. Now, as I read your answer I remember that this solution is described in the document "Footprint Naming Convention - Non-standard Component" which can be downloaded form your site. http://www.pcblibraries.com/account/user/memberdownloads.asp
Best regards
Guido
